2wd box question
Discussion in 'The Garage' started by MTBLAZER89, Jan 23, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Ok I found a 2WD steering box today. Remanufactured never used. The guy doesn't know what year it was for. How do I tell the difference between the two different types. I have an 89, but I have lines for a 78 is it possible to just use the older lines on mine to use the older box?
    What do you guys think this is worth by the way?
  2. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    I paid 45 bucks for mine and a core charge. They wanted 75 at the Jyard I was at but nobody had bought one in like ten years and they had 50-60 in the yard. Don't know about the lines.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you can swap lines and fitting in back of pump so you can use whichever,
    80 is when fittings style changed to O ring type
    just look in the ports on the box and see if is flared type seat or O ring type,
    or try screwing in a flared 3/8" line end from something into one of the ports and see that the line is not loose when the flare nut is tight, if line doesnt move around with the nut tight then youll be good to go
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I put a box froma 86 2x burb on my 73. Had to change fitting in back of pump and bought the lines for the 86 burb. Works fine.
  5. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    what he said, good reason to replace the lines anyways /forums/images/graemlins/thumb.gif
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    /forums/images/graemlins/thumb.gif Thanks guys
  7. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    The box he had mounts to the inside of the frame. /forums/images/graemlins/confused.gif Is that for a car or something??
  8. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    Sounds like car box to me.
