2wd box?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by RGV72BLAZER, Jun 3, 2006.
  1. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    any suggestions on which year 2wd box to use for x-over? or it doesn't matter?
  2. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    Doesn't really matter - I just got a sector shaft when I did mine - and swapped it for the 4x shaft.
  3. Clockwork71
    Clockwork71 Registered Member
    Mar 23, 2006
    23
    Waukesha,WI
    I used a 2wd box from a 78'. I don't think it matters what year, just look at the line fittings on the box because the did change over the years. Not exactly sure when but they could be inverted flare, compression, or metric. Again, not sure what years.
  4. RGV72BLAZER
    Jan 23, 2006
    2,425
    thanks a lot.
  5. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Input shaft size changed around 75/76 for the steering boxes.
    Find out what your running currently and duplicate.
