2wd factory spring hangers?
Discussion in 'The Garage' started by crowley, Jul 22, 2004.
  1. crowley
    crowley Registered Member
    Oct 26, 2003
    24
    Phoenix, Az
    i have a set of factory 2wd rear spring hangers, and i realized the they will pretty much bolt right in as a replacment hanger...this would give me a bit of lift in the rear i would think, but what would the outcome be if the 4"ord shackle flip was used too?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you wanna replace the 4wd front hanger from the rear spring with the 2wd hanger? the 2wd is shorter that the 4wd, thus giving less lift. to get more lift, use the 2wd spring hanger for a home made shackle flip. you wont be able to use the 2wd hanger this way and the ORD shackle flip.
  3. crowley
    Oct 26, 2003
    24
    Phoenix, Az
    the thought was replacing the 4wd rear leaf spring, front hanger with the 2wd hanger. there is roughly a 4 1/2 difference/ drop, but you say it would work with the shackle flip?
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the 2wd hanger is shorter moving the the spring up on the frame actually lowering the truck about 2.25" (half of 4.5" cause only one side is being moved) in stead of raising it. if you put a shackle flip with it, the pinion may be to high so you may have to shim it back down.
  5. crowley
    Oct 26, 2003
    24
    Phoenix, Az
    then maybe the hangers that i have arent 2wd hangers, because holding it up to the factory k5 hanger it is deffinetly a longer hanger, it has three bolt holes down the outter flanges, the top two bolt holes would mount right in the frame...i'll try to post pics this weekend its hard to explain i guess, sorry
