2wd front end to 8
Discussion in 'The Garage' started by 1BadK-30, Oct 1, 2006.
  1. 1BadK-30
    1BadK-30 1/2 ton status
    Feb 6, 2005
    817
    Phoenix, Arizona
    ok bare with me i dont really know the terminology but what i want to do is swap in a 14 bolt into my c10. I dont want to look like a fool and was wondering if 1ton front end parts would bolt up to my c10 ifs. I read that you could but wasn't sure because frankly i have no clue what he said :haha: If anybody could give me a yes or no answer and tell me if i need something special for it to work would be awesome.
    sorry if that doesn't make any sense :doah:
  2. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    are we talkin about swapin 5 to 8 lugs?
  3. dremu
    Feb 27, 2000
    15,967
    458
    East of San Francisco
    Well, you'd hafta switch the rotors and hubs -- err, they may be one unit -- at the least. Maybe bearings and if you're unlucky, spindles and backing plates and calipers. Post up what year the C10 is, and I may haev a parts book I can check compatibility for ya.
    I did this on my dually, had to convert it to the big-momma Bendix calipers to do DRW. Worth it, mind you, but I had to swap everything from the spindles out. Anyway, yoru case is different, but certainly doable.
    Note you won't get higher weight capacity without also changing springs, etc, so you're just gonna have a 1/2-ton with 8 lugs. Which is not a bad thing... but don't go towing a tank with it :)
    -- A
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    personally, if i were going to attempt such a swap, i'd get a whole parts truck. unbolt the entire front suspension crossmember, and bolt it into your truck. out back, you'll have to swap the spring hangers if you're running a 1 ton rear. personally, i'd go with a 3/4 ton setup with a 14FF, it'd all be a direct bolt in, unless you're swapping spring lengths in the rear and you'd have to move the rear hanger around (the holes should already be there)
  5. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    766
    Granbury, TX
    I did this with my Brother's truck. (86 C10)
    you have to change EVERYTHING from the control arms out... and the studs which the upper control arms mount to are larger, so they need to be changed (which basically requires the engine to be out of the vehicle, or you drop the front cross member) Look at were those studs are to get an idea what you are in for...
    you also pretty much need to add 3/4ton brake booster and master cylinder... or you wont stop in time if you have wieght in it.
  6. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    ouch this sounds like more time consuming then i thought, i was hoping to swap out the lugs and be done haha. The truck is a 1982 c10, custom deluxe if you possibly need it.
    thank you very much guys for the reply.
