2wd pitman arm nut
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by funkycold, Jun 24, 2004.
  1. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    i have swapped the steering shaft in the gearbox and need to get the nut for the pitman arm.
    Does anyone know what size the nut is? Can i get a standard nut or does it need to be a special nut?
    thanks for the help
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    IIRC it is a 7/8" coarse thread.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Get yourself a lock washer and if possible a lock nut too. Both me and Matt (the guy posting above) have had that steering arm nut loosen up on us since we did crossover. Even with a lockwasher.
    Harley
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Harley
    I've had the same problem too. Last time I used tread lock and a lock washer and it has held so far.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I just put mine back on today after replacing the steering box. I used a 2' long breaker bar to tighten it. /forums/images/graemlins/thumb.gif /forums/images/graemlins/eek.gif I'll be double checking now that I know that people have had theres come loose.
    How many threads do you guys have sticking out after you tightened the nut? I've only got one or two max.
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I check my pitman arm nut every time I change that oil. It's pretty easy to grab a 1 5/16 wrench and make sure it's good and tight. Also, I'm pretty sure it's not 7/8 coarse. I think it is pretty fine, probably a 7/8-14 like a Dana 60 pinion nut. I prefer a locknut over a lockwasher, too.
