2wd question,dodge front lift??
Discussion in 'The Garage' started by boggerless, Jan 20, 2006.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    OK,its a 79 d-300. upper and lower control arms. the shocks go through the coil springs. what can be done to lift it some shy of spindles(i dought they even make e;m for that year).??my friend asked me and i can;t think of anything except those helper coils you bolt outside the shocks. he doesn't think they will fit. any help would be greatly appreciated. thanks gentlemanst:D
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    daystar makes a spring spacer that you put between the coil spring and the frame. it would probably throw the alignment off though. also would need longer shocks.
  3. boggerless
    May 26, 2003
    22,728
    96
    WHATS UP TJ???is everthing running now?thanks for the info. it sounds pretty inexpensive also.:D
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yea, i think they are like $50 for a pair, ive seen em on ebay once on a while.
    finely got my truck running, waiting on my cousin to get his blazer running better, tbi issues.
  5. cutlasskid86
    cutlasskid86 Registered Member
    Oct 15, 2005
    13
    San Antonio, Texas
    Theres is a how-to for a 6 inch lift over at RamChargerCentral.com
