2wd same as 4wd power steering pump?
Discussion in 'The Garage' started by barneybasher1010, Nov 6, 2005.
  1. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    Will a 2 wheel drive power steering pump fit on a 4 wheel drive?(Both chevys)
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Yes, just make sure they are the same design. i believe 1980 and earlier used the flare seat lines and 1981 and later used the O-ring lines.
  3. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    Are they the same 6cyl. vs. 8cyl.?
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The only difference is going to be the clocking on the bracket, and also the line configuration i spoke of. There also is the hydro boost style with no resevoir on the pump but those aren't as common to find.
  5. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    No they aren't..
    A P/S pump off a 4.3 VEE six might fit a small block,I've never tried one,but they do share a lot of parts --but the straight sixes use a pump thats nearly identical,but the pulley wont line up with a small blocks pulley setup(not sure if its just the pulley itself,or if its the pump shaft that is longer)..
    I never bothered to see exactly why--I was too PO'd after putting a like new "spare" P/S pump from my 250 six onto a 305 motor,and all was well until the fan belt didn't line up! :doah: :angry1:
    You can swap out the "bung" fitting the pressure hose scews into,if the pumps fitting is different than your original..
    You can swap the "resivoiur" from one pump to the other..thats what I had to do--my 305's pump had a hole poked in the resivoiur,and after I found out my other pump wouldn't fit,I swapped the resivoiur from it onto the original V8 one..I think the hydroboost pump is the same guts,only the resivoiur is different,AFAIK...never had to mess with my diesels P/S pump--hope I never have too either.. :crazy:
  6. Cornfield creations
    Oct 19, 2005
    1,283
    Jasper, Indiana
    I don't mean to steal the thread, I just had a little question about the different pumps.
    So the pump itself won't work from a 250 inline to a 350? But the reservoir will swap over?
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Same pump just possibly different pulley.
  8. Cornfield creations
    Oct 19, 2005
    1,283
    Jasper, Indiana
    Could the pullies be swapped? Are the pulley shafts the same diameter?
  9. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The shaft's are the same diameter 3/4" IIRC.
  10. Tominator II
    Tominator II 1/2 ton status
    Nov 5, 2005
    280
    South Park CO 80440
    Its usually a pain to swap reservoirs without pulling the pulley ,if its pressed on you need a puller, only takes a bolt with a nut and washer to re-install, I have used car pumps on trucks many times.
  11. rockspider
    rockspider Registered Member
    Sep 9, 2004
    37
    ? Hydroboost brakes pump different or not?
    I have had no way to check personally, but a friend of mine, having unsuccesfully tried to swap an hydroboost brake system from an M1008 diesel on a gas K5, keep telling me that the pump of the Hydro-equipped trucks have higher volume (or pressure?) pumps than the others.
    Comments?
  12. Tominator II
    Nov 5, 2005
    280
    South Park CO 80440
    My 93 k3500 has the hydroboost setup and 2 of the high-pressure hoses have leaked so that makes me think the pressure is pretty high because I almost never have had hoses leak on my older rigs.
  13. DaPlumber
    DaPlumber 1/2 ton status
    Apr 4, 2003
    212
    Holland Oh.
    I have 69 c-10 with a smal block My pulley s dont match. My power steering pulley is about a 1/4" short.
