2wd sector shaft clocked for 4wd steering?
Discussion in 'The Garage' started by MNorby, Sep 8, 2006.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    Wan pondering and figuring steering correction on my 71. Basically put a 4-5" lift on it and need to correct steering angles. Prog just go with a raised steering arm if I can find cheap but was thinking, If I put a 2wd sector shaft in the box can I run that Ford superlift pitman arm like we use on our crossover steering setups but clock it for front/back steering? The secter is splined all the way around with 4 misplined sectoins around it. Anyone try that? If it worked I would go that route then when I could scrounge a crossover steering arm I could re-index and be done. Make sense?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Yes you can. I checked when I put in my crossover just incase I had to revert to push/pull on a trail run.
  3. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    sweet, I thin I will just order one of those pitman arms and put one of my extra 2wd sectors in my box and be done then weh time for crossover jsut a steerng arm and draglink
