2wd sector shaft in 4wd box
Discussion in 'The Garage' started by muddybuddy, Oct 15, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey there im doing x-over steering, and am still in need of a 2wd steering box. will just swapping in a 2wd sector shaft into my 4wd box work? if so what do i need to do to get it to work?
    thanks,
    james
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    Throw that POS away and get a 2wd box, it's just easier. :D
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    If you like the box you have, just get a 2wd shaft. It's a direct replacement.
  4. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Is there any adjustment needed when doing this or is do you literally just drop it in and go?
  5. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Shouldn't be any adjustment, just undo the four bolts on the top of the box and the pitman arm. I just pointed the wheels straight, pulled the old one, oriented the new one the same way, and dropped it in.
  6. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Same hear, way easier than pulling boxes. Left both boxes attached to the frames.
  7. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so the 2wd sector shaft is all i need right, and its a direct replacement?
  8. bernman
    bernman Registered Member
    Oct 4, 2005
    26
    ny
    its pretty straight foward, the only thing to remember is one may need more or less sector adjustment than the other ( the 5/8 nut and allen key stud on the top cap)
  9. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
