2wd Sm420 info needed
Discussion in 'The Garage' started by GMCLegacy, Feb 17, 2003.
  1. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    does anyone have pics of a 2wd SM420 in a 67 (or so) model pickup. i am looking to put a 420 in my pickup and have found a tranny out of bus, but the crossmember is tied into the bellhousing, i think this is because the motor mounts on the bus were located differently than on our pickups. It would seem that a lot of weight would be unsupported if the only crossmember is on the bellhousing.
    Marc
    mrspetos@mtu.edu
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I am not sure about the later models, but the mounts are like that in all '67 - '72 2WD pickups with manual trannies. There is no real tranny crossmember, just frame mounts that tie in to the tabs on the bottom of the bell housing. The tranny just hangs off the back, unsupported.
  3. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
    hmmm, thanks for the info, i guess if nobody has had issues with the setup, works for me
    thanks
    marc
  4. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    If you are going to swap 465 for 420 get the bellhousing too.The center hole is diff. size.Traded for one couple weeks ago for LOOONG term 68SS El Camino project.Now I need ind.205 from Ferd .Gotta git 88 done so I can go on wiht 68. /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
