2wd steer box
Discussion in 'The Garage' started by Scott39, Jan 20, 2005.
  1. Scott39
    Scott39 1/2 ton status
    Jan 3, 2005
    214
    Lakewood, CO.
    What does it take to put on a 2wd steer box on a 91 blazer 4x4, new here, if this has been answered already with pics, please give me a link to it.
    Thanks, Scott
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Unbolt 4 wheel drive box. Bolt on 2 wheel drive box. Also use a steering box brace, this item is not optional. You will need a box that fits your hoses, somewhere around '81 or '82 and newer, or you can use an older box with the older pump and hoses. The only difference in the boxes through the years is the type of hose connections.
  3. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    offroad design.com or the vendor form for box brace . 1 of the best add ons on my truck . iam sure every one will agree. like he said unbolt bolt and blead and run.
  4. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Are you trying to do it for crossover steering? If so why don't you just change out the sector shaft from a 2WD box and put it in your current one? That's what I did and it only takes like 15 min's. Most of it was getting the pitman arm off the old one:mad:
  5. Scott39
    Jan 3, 2005
    214
    Lakewood, CO.
    I`am going to use Off Road designs hysteer kit.
  6. Scott39
    Jan 3, 2005
    214
    Lakewood, CO.
    I wasn`t sure if the 2wd box bolted to the outside of the frame or the inside.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    all full size trucks bolt outside rail
    cars and s-10s are the inboard ones
    4x2 and 4x4 are same thing
    c-10 c20 c30 k5 k10 k20 k30, duallies, burbs blazers, pickups, chassis cabs, all of them all same deal late '68/early'69-up(integral ball and worm power steering)
    79 older are flare seat lines, 80-up are o rings seats
    the only thing different between them all is the pitman arm shaft diameter
    2wd boxes are cheap, 20 or 30 bucks tops, put in 2wd shaft and youre all done, cept for pitman arm
    gonna need a pitman arm puller tool, they are cheap, pull the arm off then remove four top cover bolts and pull the shaft out of the box, put in 2wd one andmm bolt cover back on
    done
    about 10 minutes overall, or so, dont even need to remove box from truck
  8. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    unless the pitman arm decides to give you your monies worth!!! :grin:
  9. vw62rag
    vw62rag Registered Member
    Jan 1, 2004
    78
    topeka, KS
    im a noob, but why use a 2wd box? whats the advantage over a stock 4wd one? jus would like to know cuz mine is coming off soon cuz i think my frame is cracked (i gota repair it and get one of those sterring box braces, who all sells these BTW?)
    thanks!
  10. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    the 2wd box is for crossover, you need it for crossover cuz it has muiltiple settings so you can make it go side to side needed for crossover, and the 4wd box only has the front to back movement.
    not to hijack but can i get a new 2wd shaft from some where?
  11. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    go to the junk yard with large pry bar BFH a 1 and 5/16 socket with cheater bar for pitman nut there are four small bolts on top of the sector shaft unbolt put a catch pan under neath and pull that sucker out. Install is the same way but make sure to have the steering box centered before you start. Piece of cake.
    Jesse
  12. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    offroaddesign.com will have what you want for a steering brace they have bolt on or weld in for the already cracked.
