2wd steering box/crossover question
Discussion in 'The Garage' started by original balzer, Jul 30, 2005.
  1. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    will any 2wd steering box work for a crossover set up? what i have is a 1980 2wd 1 ton dually it also has the hyro assist brakes is it hade to swap that to a vaccume assist truck?
    balzer
  2. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    the old style had diffrent line fittings. but will bolt up to your frame just need to use pump and hoses to fit. swap the whole setup.:wink1:
  3. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    The early ones were standard and the new are metric but you should be able to get an adaptor at a hose shop for the box.
  4. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    It may be exaxtly what you're looking for if your rig is 1980 or earlier. I believe the switch to different fittings was in 1981.
    Eric M.
