2wd steering box questions
Discussion in 'The Garage' started by mudman83, Jun 23, 2006.
  1. mudman83
    mudman83 1/2 ton status Premium Member
    Feb 11, 2004
    141
    Mesa, AZ
    Will a two wheel drive steering box work with front to back styeering? I need to change mine and know that someday I will want cross over, but have to keep the stock steering for now.
    Thanks,
    Kyle
  2. 74 chev
    74 chev 1/2 ton status
    Sep 30, 2004
    159
    Concord,CA
    nope you need the 4 wheel for now then you will have to swap to the 2 wheel gear.
  3. mudman83
    Feb 11, 2004
    141
    Mesa, AZ
    Man that sucks. Thanks for the info though.
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Why would it not. Just put the pitman arm 90deg off from where it is mounted for the crossover. It would move front to back just fine...
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    negative...the 2wd sector shaft and pitman are are keyed to only go on one way...
  6. readymix
    May 30, 2004
    6,706
    26
    News to me since I just installed one a few weeks ago.
    The 4x4 shaft is keyed for one way. The 2x4 shaft is keyed every 90 deg.
    Or am I completly lost here?
  7. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    mine was only keyed to go on one way.. I may be mistaken though b/c it has been like a year and I have def. been drunk and slept since then...
    Chris
  8. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I agree my 2wd box has four key-ways and a big nut on the bottom. The 4x4 has a flat spot on the shaft so it can only go on one way. At least all the boxes I have seen were this way.
  9. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Yep that is the way mine is too
    was just messing around with a two wheel drive box today and and it looks as if it should work just fine if you turn it 90*
  10. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I would assume that as long as you have the crossover pitman arm on the 2wd box then YES you could install it so that it will push/pull. The 2wd box's are clocked every 90*
  11. mudman83
    Feb 11, 2004
    141
    Mesa, AZ
    What year and truck should I get one off of? Also Should I get the normal 2wd pitmann arm or do a need another one?
  12. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The year will depend on what type of fittings your lines use. Up until 1980 the lines had flare fittings then starting in mid 1980 they changed to O-ring style fittings. You will need a pitman arm from ORD for use with crossover steering then just install it so that it can push/pull.
  13. mudman83
    Feb 11, 2004
    141
    Mesa, AZ
    OK thanks,
    Kyle
