2wd Steering Box
Discussion in 'The Garage' started by daleearnhardt01, Jul 20, 2004.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    What years work for doing crossover?
  2. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    All years of 2wd box will work. You want to match your new box to your old lines. The change was around 80 (from inverted flare to o-ring), so you will want an 80-up box for your 90. /forums/images/graemlins/thumb.gif
  3. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    And that includes the new body style C/Ks?
  4. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    No, I think they mount to the frame different than our trucks do. I can look on my 97 to confirm, but you should easily find a 2WD box 80-87.
  5. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    If you can't find on that has the same hose fitting then you can just swap the sector shaft. That's the only difference. /forums/images/graemlins/waytogo.gif
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    that was so easy.. although I didnt expect that much of a mess.. had to get the power washer out... /forums/images/graemlins/whistling.gif
