2wd steering shaft or box??
Discussion in 'The Garage' started by Bhintz, Dec 29, 2004.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    looking for one of these to put on my k5 (for crossover) and I was wondering whats easier to install the whole 2wd box or just the sector shaft? and is there a write up any were since I zero experience w/ any steering box
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    the 2wd shaft isnt that hard but just swapping boxes is so much easier.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I could have a sector shaft switched out before you could even have one bolt out of the steering box.
    Change the shaft.....much faster.
    If you don't have a bolt on brace, get one before you install your crossover. A week after I installed my crossover, my steering box fell completely off the frame.
    I've got them in stock, as does ORD. Whoever you get it from, just make sure you get it.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I agree with Tim. Shaft is the easiest swap. You could swap the steering shaft twice before you ever got the steering box off the frame let alone back on.
    Harley
  5. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I'll jump on this too, changing the shaft out took me a total of 15 minutes from one box to other:D
  6. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    When replacing the shaft only, are there any adjustments? Isn't there a "lash"(?) setting between the shft and the pinion like gear in the box? I know there's an adjustment nut/stud thing on the outside. How do you set the new shaft up correctly?
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yes the adjustment is the lock nut and screw there on top of the box
    theres less work to do to swap the shaft out than the entire box but neither is difficult to do
    still need pitman arm puller either way
    leave box on frame and pull arm first then unbolt top cover and pull shaft out top of box with the cover and all
    the only thing is that you risk seal leakage doing it this way
    thats all
    good luck
  8. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    I realize the shaft swap itself is easy and also easier than swapping a whole box but what about the adjustment? Can someone explain the actual adjustment procedure?
    TIA
  9. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    would like to know how to and what are the steps for taking the shaft out, I read R72K5 said but is there more to it
  10. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    1. Remove pitman arm.
    2. Remove 4 bolts on top cover.
    3. Place drip pan below sector shaft.
    4. Gently tap shaft upwards.
    5. grab cover from the top and pull it out.
    It really is that easy to remove the shaft. I would like to know more about how to adjust the lash though.
  11. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    JUST for everyone's info...incase this comes up in a search:
    Matt Hodges of West Texas Offroad says:
    The adjuster stud and lock nut have to be adjusted tight enough that you don't have any slack in the steering wheel but loose enough that don't feel the steering bind in the center of the steering gears. It's an easy process for me to do but trying to explain it is a little hard.
    I don't even know where my book is that lists in/lbs ratings is anymore. I haven't used it in years. they aren't always right anyway and I have my own methods that work better.
    easiest way for me to tell you how to do it is to take the box off and tighten that adjuster stud a little at a time until while you turn the input shaft with a wrench from lock to lock. as it the adjuster stud goes in you will feel the steering get tight in the center of the steering arc or halfway between locks. you then want to back the adjuster stud off until you can't feel that tightness in the steering in the center. Then lock the nut down.
    hope this helps and not confuses.
  12. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    don't trust the inch/lbs rating. It is totally different depending on the lubrication of the item (warm, cold, dry, soaked, ect).
    This was in an old post I replied to. It is how I have done 2 boxes so far with no problems (both DD's).
    clicky
    PS somebody dug like I did and copied and pasted :deal: :shame: <- blake :grin:
  13. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    I tried Tightening the adjuster but it only helped a little still have slop in the steering. Need a new box soon.
  14. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I have always adjusted them installed. Turn the wheel side to side and turn adjuster till you feel a little bind/resistance coming off center, then back off adjuster a hair till resistance is gone. You gotta have both front wheels in the air to feel the resistance. I do it this way cause its easier for me to tell where center is.
