2wd Th350 into my 4wd truck?
Discussion in 'The Garage' started by Calclips, Feb 27, 2003.
  1. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I've got a %&$#ed up Th350 in my truck, but we've got a junked-out old van here at my house with a th350 in it that has like 6000 miles on it. I've heard that I can just unbolt the tailshaft off of it and cut the output shaft to the proper length and be good to go. What I wanna know is, is there any truth to this statement... and if it is true... how do I go about cutting the output shaft?
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    In order for you to use a 2wd TH350 in your 4wd, you will need to do 2 things....Remove the tailshaft housing(easy) and swap in the TH350 4wd output shaft(not easy). The difference between the 2wd & 4wd output shaft is substantial. You can't just cut of the extra length, because you will have no splines left on the shaft.
    You will need to disassemble both trannies to do this. It would almost be easier to rebuild your 4wd tranny. Good Luck! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    If you've got more time than money it isn't all that hard to switch the output shafts. You would just have to remove all of the guts from both of the tranmissions /forums/images/graemlins/rotfl.gif
    By the time you got all the suff out of the second one, you'd prolly have enough experience to put the good one back together. I managed to do it, and I'm dumb as a rock /forums/images/graemlins/shocked.gif
  4. Calclips
    Apr 4, 2001
    1,005
    I've got a spare 4wd output shaft that I got out of a parts tranny I had sitting on a shelf in my barn. I wanted to avoid taking it apart because I tried to rebuild the one thats in my truck right now and it dosen't work. Of course I don't think its necessarily something that I did wrong, the case was pretty trashed and I had to put a ton of helicoils into it to get it to go back together. I just thought that I heard somewhere on here that I could just cut the shaft on the 2wd one and it would work... so much for wishfull thinking. /forums/images/graemlins/frown.gif
  5. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    For a TH400 you can whack off the last 1/2" of the shaft, but not the 350!
    sorry,
    andy
  6. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    What do use to cut the shaft with I have a tci prepped short tail shaft TH400 I bought it to put in my dually but I have a TH400/np205 setup the trans is fried I'd like to make my dually a 4x4 I have a 79 k-30 frame I can use I also have 2 talldecks that I want to use .....Just what I need....... another project /forums/images/graemlins/truck.gif
