2wd th400
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77scottsdale, Apr 21, 2007.
  1. 77scottsdale
    77scottsdale Registered Member
    Dec 17, 2006
    93
    georgia
    will a 85 2wd th400 mount to a 77 th350 np203
  2. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,029
    1,347
    Kzoo, Mi
    Your asking if a 2wd THM400 will bolt to a NP203 that was behind a THM350? The 2wd 400 will not directly bolt to the 203, but I think you can change the ouput shaft and tailhousing to make it work. I don't think you can search as your not a member, but someone else should chime in also.
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Nope .
    The input shaft is 27 spline on your 203 and you will need a 32 spline input. The TH400/203 set up has the shortest TH400 tailshaft of all and as far as I know there is no ther application that uses it. You will need to get more parts to make that 203 work such as the correct out put shaft for the tranny and the correct adapter for the 203 and the correct input gear for the 203.
    HTH's Tom
  4. 76zimmer
    Nov 14, 2005
    23,029
    1,347
    Kzoo, Mi
    there we go, thanks for clarifying my inept attempt at an answer Tom.
