2wd to 4wd 3/4 ton big block burban
Discussion in '1936-Present Suburban' started by GearHead, Jan 16, 2003.
  1. GearHead
    GearHead Registered Member
    Feb 21, 2001
    5
    CA
    I have a 3/4 Ton Burban and it is 2wd. The body is cherry and the interior too, plus it has a 454 in it. I guess these are my reasons for wanting to keep it and convert it. I am thinking if I do the conversion in stages it will be easier for me (hard for me to go a week without driving it /forums/images/graemlins/grin.gif). Anyway I thought the first part that I would tackel would be putting in the front axle. I have not even seen a 4wd front end on a Suburban yet too see what is involved. But I wanted to ask if anyone knows weather or not the 2wd 3/4 Burban frame I have would have the holes for mounting up the spring purches for the leafs or will I have to weld them on? Oh it is an 1986 by the way.
    Thanks for the help. I hope to be a 4wd burban owner soon...
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Without seeing 2wd front frame parts, i have no idea on that part. What I do know is you will have to install a body lift in order for the transfer case to be able to clear the center hump in the body, on a 2wd it is alot lower than on a 4wd.
  3. GearHead
    Feb 21, 2001
    5
    CA
    Cool anyone know how much of a body lift I will need? I guess that would be the first project to do. /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    If i remember right, a 2" will work, 1" will not i know that.
  5. GearHead
    Feb 21, 2001
    5
    CA
    Sweet! I will start with that then move onto buying the parts I need to do the conversion.
    Thanks /forums/images/graemlins/thumb.gif
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    basically all you will need to finish the rest is a 4wd front end, tcase and adapter, front driveshaft, remove tailend of tranny to accept tcase. If i've missed anything, someone else will chime in.
  7. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I'd go with the Performance Assessories 2" body lift. I believe Muddytazz put this on. I bought mine, just haven't had a chance to install it yet. I also bought the poly bushing kit from Energy Suspension. Paid 150 tax included out the door (& under table) /forums/images/graemlins/thumb.gif for both. Check to see if yours are still good. If so-so, then do this at the same time as you do the body lift to save you a bunch of trouble and work down the road. Good luck with the conversion. My buddy is a mechanic & he likes the challenge of doing custom work. One good thing with the 2wd converted to 4wd is the lower insurance, providing you don't tell them. /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  8. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    i thought you could just use a center hump from a 4wd truck and avoid the whole body lift deal. i could be wrong though
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    You could cut out the center humps from both vehicles and swap and weld it in if that is what he wants to do, its just that a body lift is easier.
  10. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Can't you just use the crossmember from a 4x4? Wouldn't that lower the t-case automatically? Just wondering out loud...er typing kinda loudly anyway!?!?!?
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    That will lower it a little bit, but not enough, if you compare the center hump on a 2wd and a 4wd, there is about a 3 to 4 inch difference in height.
