2wd to 4wd conversion
Discussion in 'The Garage' started by s1037s, Dec 15, 2005.
  1. s1037s
    s1037s Registered Member
    Oct 21, 2005
    22
    Hopkinsville,Ky
    I have trie dsearching but cannot get the info i need. I have found a 3+3 with a 6.2 2wd ff14 rear. I want to convertit to 4wd and bob the bed and frame. does anyone have links to pages to show the brackets i need. i want to run 52's up front. I have a divorced np202 so that is not a problem. i have an axle for the front also. any help appreciated.
  2. freeflow
    freeflow 1/2 ton status
    Nov 6, 2004
    274
    alexandria, minnesota
    its not that hard 2 do, i just got done converting my 2wd suburban it is now 4x4. it was pretty easy, just get the brackets and hangers from a 4x4 frame, i had all the mounts and everything and it only took be about 6 hours total, 2 get rivets out, clean the hangers up a lil bit, measure, align and drill new holes.
    Now i just gotta get a 454 4x4 crossmember and a 205 case and the big stuff is done.
    good luck man
  3. fordfreak300
    fordfreak300 Registered Member
    Aug 20, 2005
    29
    Palm Springs CA
    freeflow you didn't happen to take any picks along the way did ya? I amabout to do the same thing and just wanted to see what took place before I start doing it. I am looking at starting in january after x-mas. What did you have to do for the engine? I know the front cross member that hold the engine in has to come out and you need new motor mounts I belive. I am hoping to get all that off of a donor truck but i would liek to know for sure before I get started. Anything that I can start aquiring before hand will only benefit me. That way I can start seeing what all has to go where.
