2wd to 4wd?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Big_Ugly_Diesel, Nov 26, 2001.
  1. Big_Ugly_Diesel
    Big_Ugly_Diesel Registered Member
    May 7, 2001
    60
    Fort Worth, Texas
    I want to convert my 84 sub from two wheel drive to four wheel drive. I have heard all the holes all already in the frame, I would just have to grind off the rivets and bolt up the leaf spring mounts. If anyone has done this I would greatly appreciate the help before I get into a project I cannot finish.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I'd suggest crawling under a 4x4 and taking some frame measurements, then doing the same with your 2x4. I think you'll find that they aren't the same. [​IMG] Also, the transmission is different, plus you'd need to add the transfer case, the correct steering box, etc., etc. It's really much easier to just sell your 2WD and use the money towards a nice 4WD. [​IMG]
  3. Big_Ugly_Diesel
    May 7, 2001
    60
    Fort Worth, Texas
    I already have the two wheel drive sub and a four wheel drive blazer so I think I have all the parts I need ( steering box, trans etc.)
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    So get out that measuring tape and see if the parts will fit! [​IMG]
  5. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    Go for it. The hardest part that I can see would be the front crossmember. Anything is possible with GM.
    Keep it simple <a target="_blank" href=http://coloradok5.com/gallery/album71>http://coloradok5.com/gallery/album71</a>
  6. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Has anyone done this? what happens to the spring pocket from the 2 wheel drive?
    I'm not saying it can't be done, anything can be done if you have the tools and enough beer[​IMG]
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  7. Rockjunkies
    Jul 26, 2001
    385
    Oklahoma
    The whole 2wd crossmember will unbolt taking the entire front suspension with it. Except for the idler arm wich will have to be unbolted seperately. You can even sell the front suspension settup to someone that would like disc brakes on there 2wd 63-70, there are a few looking for this settup.
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    LSNED.
    aren't the 2wd's a full frame?
    55 Willy's
  9. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    The frames are completely different and will require much custom fabrication to make it work. You either need to find a 4x4 burban frame to set your body on, or you need to sell your truck and buy a 4x4. IMHO
    '85 K5 : Run it til it breaks, then fix it and go again!
  10. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I had looked into this when I had a 2wd pickup and it looked like it would require the whole front of a 4wd frame to be grafted on. Unless you really REALLY love this truck, it's not really worth the work IMO.
    On Furds it's real easy, but not on chevys [​IMG]
    Don't hit me, Mr. Moderator... I'll go back on topic... I swear![​IMG]
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer>www.geocities.com/muddin4fun79blazer</a>
  11. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Check over on Pirate, there is a thread about the same thing ( I think its in the Chevy section).
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  12. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    frames are the same
    crossmembers are different
    get the naysayers to break out THEIR tape measures
    I run a 2WDR one ton frame using all 1/2 and 3/4 ton brackets
    **** all to it but to do it
  13. Big_Ugly_Diesel
    May 7, 2001
    60
    Fort Worth, Texas
    Gracius for the info. Sounds like I will just have to get off my lazy butt and do some measuring.
  14. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    I sure hope 77chev is right...
    me and some friends have an 8 door suburban (yes, stretched like a limo) thats 2WD.. we have a K20 donor for parts, that project starts someday. maybe mid-'02.... anyhoo we were planning on at least SOME fabbing... if the frame rails are the same that will be a huge help.
    mike
  15. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    My suggestion would be if you know anyone in the car biz, have them keep an eye open at auctions for a rust bucket 4x4 Sub, around the same year as yours. Or look in the papers. They should be cheap, either way. Put your body on that frame, and sell the extra parts, engine etc.
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
