2wd to 4wd
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by odee, Feb 6, 2002.
  1. odee
    odee Registered Member
    Feb 5, 2002
    15
    Big Stone Gap Va
    Hello all I'm in the process of swaping engines in my sub. While engine is out it was talked about putting a 4wd frontend and transfer case in it. Has anyone here pulled off the swap? I have the crossmember for the engine mount and spring hagers. Is there any difference in the motor mount that bolts to the block between 2wd and 4wd? thanks
  2. dyeager535
    26,980
    IIRC, 4wd has the crossmember forward, underneath the balancer, and two "stub" crossmembers that the motor mounts bolt to.
    2wd has a large crossmember directly under the oil pan, I'm assuming to stiffen up the independent front end.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    nothing to it
    hole saw the shackle mount
    bolt in cross members
    keep 2wdr steering box for crossover
    formerly 77chev
    still a jerk though
  4. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    I believe mj is making it sounds a little easier than it is. You will have to get the right tranny output shaft to bolt up to the transfer case. There's some more stuff I don't remember.
    Chad
    '73 Blazer,383,400,Atlas II,D60/14 Bolt,traclok/detroit,39.5 Swamps
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    you should reply to him
    when you reply to me refering to me in the third person it looks strange in my email
    formerly 77chev
    still a jerk though
