2wd to 4x4 ?
Discussion in 'The Garage' started by NoReGrEtS, Jul 6, 2006.
  1. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    has any one on here converted one before? I have an 88 burbn and I'm sure the front k member is tweaked and the frame is straight sooo I'm thinking of converting it. its got 125k 454/400. new tranny and the motor runs great. what do you guys think? I should just fix it but I cant help wanting to change it. its a curse
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    When I get to doing mine, I'm going to try trimming down the susp. crossmember for diff clearance. That way (I hope) I can avoid having to replace it with the proper 4x4 engine cradel.
  3. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    I'd just replace the tweaked cross member and swap all the parts you want over, it's a ton of work and time to make this conversion and have it come out useable. (I've done it once, and will never do it again)
  4. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I found this....
    http://www.chuckschevytruckpages.com/2wdto4wd.html
    and this...
    http://www.fullsizechevy.com/forums/showthread.php?t=63037
    I don't really agree w/ everything they say but it's a start to your search. One of the main things was in the first post he said you'd need a "4wd transmission" I think that you wouldn't have any problems putting a different tail shaft in your tranny to bolt up to the new tc you'd have to get instead of the long tail shaft that goes to the driveshaft.
    -Avery
  5. NJBLZ
    NJBLZ 1/2 ton status
    Jan 4, 2005
    128
    New Jersey
    I've seen it done before. The guy said it wasn't that hard, he had to make a some new holes in the frame. He is also an experienced welder/ fabricator. I have intentions of doing the same thing for my tow rig. I would want to have a complete donor vehicle or chassis parked right next to the project truck to make measuring and part swapping easier.
  6. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    me and a buddy just recently got done doing that on his 78 burban also with the 454/th400 it wasnt too bad. Id really rather not do it again but it was a good experence. Basicly you will need to put a difrent out put shaft in your tranny or do a divorce mounted case. Another thing is youl have to drill like 2" holes in the frame for the shackle hangers. Then the front spring mounts you can iether use original style and drill rivits and holes and whatnot or you can go with a crossmember style setup. Iether way reqires a fair bit of work if you have acces to fab equipment then the crossmember style is probly easyer. but anywho longstory short unless you are an experenced mechanic/ fabricater with access to a good set of fab tools ten its not quick or easy.
  7. warrior454
    warrior454 1/2 ton status Premium Member
    Jul 22, 2004
    101
    13
    ontario canada
    I converted the 2whl blazer i got out of Texas last year into a 4x4 when i stripped down my rusted out frame and body bit of work but not hard to do
    heaviest part was the 2 wheel drive suspension to get rid of
  8. NoReGrEtS
    Nov 7, 2005
    848
    Thanks for all the info guys!
    I was thinkin of just 4 linking the front that way all I have to do is weld the tabs to the frame and axle (still need to do lots of math to get it right) then buy some used king coilovers, tons of them at race-dezert.com, then go with a divorced t/c that way I can keep the trans 2wd, axle I would need is a d44 so I can run crossover (2wd steering box). Im going to see if I can straightin the stuff up first but If I have to fix it with lots of money Id rather go 4x4
    thanks for the help:bow:
    Shawn
  9. mike n
    mike n 1/2 ton status
    Oct 9, 2003
    101
    New York
    I've done two (73 C-10 and an 84 3/4 ton 'Burb) and neither were terribly difficult.
    Having a donor 4x4 for parts is the most important thing you can have.
    Both trucks needed to have the tranny tunnel "dimpled" (read: smacked with a bfh) to clear the transfer case, since 2wd's have a shorter tunnel than 4x4's do.
