2WD vs 4WD 14 Bolt FF
Discussion in 'The Garage' started by BurbLover, Jul 30, 2003.
  1. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    So, other than the shock mounts, is there a difference? I noticed the one I picked up the other day has the shock mounts oposite of where they are on my other 14FF. Thanks.
    /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    no, unless it came out of a van, then the only differnce is 3" of length
  3. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Any idea then why the shock brackets are in the oposite side of the axle. (And yes I'm lloking at it correctly.)
    /forums/images/graemlins/crazy.gif /forums/images/graemlins/confused.gif
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Is it out of a 1 ton?
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    some of the 1 tons used different shock mounts.
  6. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Its probably a 1ton do the spring perches look to be in the same place as your other 14bolt? also what year 14bolt is it?
  7. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    The spring perches seem to be about 3 inches closer than my other 1 ton axle. Does this mean it came from a dually? Also, can someone tell/show me the difference between a dually 14B & a SRW one so that I can tell. The guy that sold it to me said it was from a SRW 1 ton. Looks like he may have lied to me.
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    If it is a 1 ton axle the shock mounts are going to be opposite of a 3/4 ton and the perch spacing would be 40 1/2" for a 1 ton axle and 42 1/2" on a 3/4 ton axle, also if it is from a 4WD the shock mounts will not hang below the axle tube like they do on a 2WD axle.
  9. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    On my (apparently) 3/4 ton FF, the shock mounts are below the axle tube. The mounts on the one ton are also below. Does this mean the are both originally from 2WD vehicles? Also, how hard is it to relocate the rear springs perches to the needed width, or can I just pull the springs inward that 1" on each side?
    Thanks.
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Yes, both axles are from 2WD vehicles. Depending on which style of spring perch you have it could be easy or hard to remove them. The stamped steel perch is much more friendly than the cast iron perches.
  11. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Perches are cast iron.
    So, could I grind them off them weld new perches on? If so, how hard is it to grind off? I guess I don't have anything else to do anyway. Besides, I only have $100 in it anyway.
    Thanks.
  12. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Thanks.
    For those of us without a plasma cutter (me) you gotta grind'em off. Buy lots of grinding and cutting disks. I spent a good 6 hours grinding off the cast perches on my 14BFF. /forums/images/graemlins/eek.gif
