2X3" Square Tube Cutting
Discussion in 'The Garage' started by rcamacho, Feb 2, 2006.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I'm going to be making my own sliders shortly.
    Q: What should I use to cut the square tube? I could pick up an abrasive wheel for my reciprocating saw our should I pick up a band saw or chop saw? I'd like to finish the ends at 45 degrees.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Chop saw
  3. midnitewarya
    midnitewarya Sounds like a problem for future me. Premium Member
    Dec 1, 2002
    1,726
    20
    SoCal
    If you don't have a table saw or a radial arm saw, I say go with the sawzall or a grinder. A good cutoff wheel on a grinder gives you a little more control, but both will get the job done. Let us know how they turn out!
    Al
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    did mine w/a chop saw and a grinder to cut a relief so i could bend the ends
  5. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    chop saw would be the easiest. Altho a plasma or a torch would get it done too.
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    How the heck do you put an abrasive wheel on the reciprocating saw??? :D
    I'd go with a chop saw (pretty useful to own IMHO)...get a 14" if you can afford it. Cutting at angles will require a larger blade...and if you want to cut faster....you don't want to drop the blade in the middle of a long, flat part....starting the cut closer to the corner helps you to "punch through" faster and make a better cut.
    Kind of hard to explain, but you'll know what I mean once you start cutting your own parts.
    :usaflag:
  7. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    you can get a ryobi 14" at home depot for like $140. Its what I have been usings for the past 8 months with out a prob.
  8. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    hell i use my 4" angle grinder to cut everything.. haha im poor but it works.. i've cut through 1/2" plate b4 with it...25bucks from home depot.
  9. rustyear
    rustyear Registered Member
    Jan 25, 2006
    19
    ROY, UTAH
    this job was practically designed for a chop saw...the ryobi for a buck forty is a good deal, no question...i did the harbor freight thing, a 14 incher with 5 discs for under $90...a noisy bastard, but it does everything i want it to do and has lasted over 8 years so far, no problems. if you do decide to buy one, whichever brand it is, make sure you grab the handle and move it a few times before you buy...the handles on some saws are ridiculously uncomfortable, it makes you wonder wtf were they thinking
