3.07 to 4.11 spacer?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Jun 10, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Ok, i want to upgrade my 3.07 to 4.11 and i was told i need a ring gear spaacer. i found some used 4.11's for $35 and the spacer is another $30. Does this sound all right?
    Check out my 73 K5 http://members.theglobe.com/xnoahx/73k5.htm
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Used for 35, not a bad price. What did they come out of? You have to know for sure cause the gear split is 3.56 and up. There are 2 different series carriers depending on original ratio. I put Richmonds in mine, the ring gear came as a thicker gear to fit the series 3 case (3.08 originally). You can use a spacer to bring the gear out, I think some manufacturers sell them that way? any way, for 65 bucks, you may not get the right stuff. Don't forget bearings and shims set up stuff and all the other costs too. HTH
    <A target="_blank" HREF=http://fwp4x4.coloradok5.com>http://fwp4x4.coloradok5.com</A>
  3. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    Check out this link they mention not to use spacers with gears. <A target="_blank" HREF=http://www.ring-pinion.com/GearTalk.html>http://www.ring-pinion.com/GearTalk.html</A> I think its in the carrier question.
    Craig
