3.08 gears..what size tires?
Discussion in 'The Garage' started by bryguy00b, Feb 28, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    could i run 33's with 3.08's?
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I'm running true 31's, and it's kinda doggy, not too bad though. And I don't/can't run in OD.
    John
  3. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    I've got 33's and it doesn't have the pickup it use to. Rides ok, but I'm about to put 235/75's back on it. (I'll probably be excommunicated from the fellowship for that remark!) Don't worry, I'm putting 35's on my shortbed. I use my k5 for towing a lot, and the 3.08's and 33 combo doesn't cut it.
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    My friend ran 39" MT Baja Belted tires on his 80 Shortbed for a while. He had a TH350...I think it killed the tranny, but he decided to do a whopping upgrade to 3.73...changing to 3.73 was a lot better.
  5. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    i run 3.08's and33's with my truck (350tbi-sm465-np208) that thing is a rocket, no doggies for me. of corse it is a 87 4x4 shortbed. /forums/images/graemlins/thumb.gif. but ive seen guys that run the 350-th350-np203 combo that run 35's and say hell yea, i guess it depends how how strong and powerful your drivetrain is for the 3.08's /forums/images/graemlins/deal.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i noticed while taking it for a spin it was a little laggy too...it will get up and go but takes longer...and my truck has 31's as well. seems to ride pretty good though..just takes a while to hit 3erd sometimes..
  7. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    Don't use OD if you want to keep the tranny in the truck. The 700's are big babies when it comes to high gears and big tires. If you just keep it in drive you should be all set.
    Ben 87 Jimmy + 89 Blazer
  8. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    306? yikes! my rig came with 31s and 3.73 from the factory, worked pretty well. 306 seems high as heck for 33s. Hell, i run 4.56s with my 35s! /forums/images/graemlins/blush.gif
    j
  9. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    wear are you getting 306 from? fdont you mean 308? my truck right now has 3.08's with 31's..stock probobly..
  10. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    interesting, i have a 350/465/208 and 3.08s and 33s also. only diff is i dont have tbi. its just fing around town but 4th gear up any grades sucks. its my daily driver so i'd like some highwayish gears but i think 3.42s or 3.73 would be good with 33s. of course a 4 speed helps tremendously. i had 3.08s with a 350/th350 and 31s and it sucked. also had a blazer with 400/th350 and 3.42s and it was perfect on the highway.
  11. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    well what is a "good range" as in rpms with speed with 31's and 3.08 do you think?
  12. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    i have no idea /forums/images/graemlins/grin.gif i've never had a tach in any of my rigs. i just go by feel and how often i hit the gas station /forums/images/graemlins/tongue.gif
  13. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    stick with something close to stock size. otherwise you are going to put more wear on the tranny, and get horribe mpg.
