3.08 to 4.10 gears
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Tice, Oct 5, 2002.
  1. Tice
    Tice Registered Member
    Aug 24, 2002
    36
    southeastern arizona
    this is probably a bone head ?,so slap me if its stupid. i need to have my rear gears swaped from 3.08s to4.10s because ifound a front 44 and i realllly need lower gears. but i want to keep the open carrier cuz my better half is buying me a lock right locker for christmas. so heres the ? (finally)can i use the stock carrier or do i have to get a knew one? the locl 4x4 shop told me it would cost 169.00. that sounds a bit pricy. thanks for any info /forums/images/graemlins/k5.gif
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if i remember corectly you should not need one anything over 4:10's like 4:56's and you would but i dont think so with 4:10's if im wrong someone will point it out lol /forums/images/graemlins/grin.gif
  3. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    You can check with any reputable gear shop....Rieder, Randy's Ring & Pinion, etc. But I'm with Mudhog, I think the carriers are (4.10 and down) and (4.56 & up), so if you stay with 4.10's you should be able to re-use the existing carrier....
    The "carrier break" isn't always the same for ALL axle types, so I might be thinking of 14-Bolt stuff and applying it to your D44/12-Bolt incorrectly.
    As a last resort, they also make what's called a "Thick" ring gear, which will allow you to re-use an existing carier, even if you choose gears past the carrier break...I have not heard of any reason why a thick gear is undesireable (strength or otherwise) so that's always an option for you too.....
    /forums/images/graemlins/cool.gif
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    i think the main difference with the thick gears is price.but as far as ive heard the carrier break is 4.10 actually it will be 4.09 on a dana 44 but you can still use the same open carrier.im also asking for a locker for chrismas.imm going for the quick lok thow i think.looks like its pretty strong.
  5. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    According to Randy's ring and pinion "D44 3.73 & down / 3.92 & up" I think the only problem with thick gears is c-clip interference, it requires grinding on the cross shaft. Although I have heard of strength issues before I can't say first hand from anyone I know.
  6. Tice
    Aug 24, 2002
    36
    hey, thanks guys, im wiating for the gears from grant in yuma( ijust sent the money fri)i have another 12 bolt is there a way to tell if they will work? thanks for the info. tice /forums/images/graemlins/k5.gif
  7. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Here are the carrier breaks for a 12 bolt according to Randy's R&P---
    12 Bolt Truck 2.73 & down / 2.76 to 3.42 / 3.73 & up #
    See also for griding etc. Randy's Tech
