3.08 to 4.11 Gears?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Scott73, Aug 5, 2002.
  1. Scott73
    Scott73 Registered Member
    May 22, 2002
    38
    Electra, TX
    Just got an '87 Blazer about 3 weeks ago. I've already got the lift and new 33s tires and wheels(not installed yet). I checked the gears and it has 3.08s in it. I was thinking about goung with 3.73s, but after reading the post "time for gears" I think I might want to go with 4.11s. How much am I looking to spend?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    depends on if you install them or have them done for you
  3. Jersey
    Jersey 1/2 ton status
    Aug 14, 2001
    234
    NJ
    Guess it depends what the junkyard charges you for a 14FF. /forums/images/icons/shocked.gif
    - Jersey
  4. Jersey
    Aug 14, 2001
    234
    NJ
    sorry, 14SF. looked again and it said you got wheels and i'm assuming 6 lug.
    - Jersey
  5. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    i have found that the magic number is $1000.00. i know it sucks but i havent found a way around it. figure 300 for the gears, 200 for install kits, very consertive 250 per axle to have shop install. this is based on 10 bolts with out shipping on the parts. sucks doesnt it. best bet is to find decent solid useable matched ratio axles to install, but they better be in good shape because brakes and ball joints cost quite abit if theyre buggered. others have said they have paid less but i dont know how they do it.
  6. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i know a guy around here that does them for 200 an axle, i got my gears, install kit and locker for 650. so grand total of 1050 isn't bad. i don't know where your located but if you want i can give you his shop name.
  7. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    Installed?? That would be worth the drive /forums/images/icons/grin.gif
