3.08 to 4.56 Conversion - is it possible
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1986Blazer, Dec 8, 2001.
  1. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    Just a quick question.....
    Can the factory 10 bolt front with 3.08 be converted to 4.56 without major surgery. Or, does it need a new carrier or will I need to get a D44 or D60. I will eventually swap in a D60 but until then, I want to use 4 wheel drive and my rear is about to be 4.56. So, if the conversion to 4.56 is simiply a new R&P then I'll do it, but if not, then I'll just live without 4 wheel drive.
    <a target="_blank" href=http://www.geocities.com/keywestk5/KeyWestK5.html>http://www.geocities.com/keywestk5/KeyWestK5.html</a>
    So I says to him, I said, "get your own monkey."
    1986 K5, 350 GM Crate, 700R4, NP208
  2. I think I've read that the cut off point to swap carriers is 4.11, I'm not sure though. Someone else can tell you for sure.
    American by birth, Marine by the grace of God
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    <a target="_blank" href=http://www.ring-pinion.com/gear/g1199.html>carrier breaks</a>
    <font color=green> Too bad ignorance isn't painful </font color=green>
  4. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Yep, the 10 bolts can. And it is just the R&amp;P.. I have both 10 bolts and 4.56's...Dan
    If it ain't broke.......Don't fix it....
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
  5. 1986Blazer
    Jun 13, 2001
    511
    Thanks Dan...
    Did yours come as 4.56 or did you upgrade from a lower ratio, maybe a 3.08?
  6. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    you can get 4.56's for a to bolt. I've check into it cause that's what I'm doing to the front.
    Don't hit me, Mr. Moderator... I'll go back on topic... I swear![​IMG]
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer>www.geocities.com/muddin4fun79blazer</a>
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    The carrier's are the same for 2.73 and numerically higher all the way to 5.57 and anything higher, if it exists. All you'd need is the R&amp;P.
    Red 1989 GMC Suburban SLE V1500 - TBI 350, 700R4 w/ shift kit, Quad-shock front, 31/10.50/15 Pro Comp MT, 4.10 gears, Duals off cat
