3.08's to 4.11's. Must I change the carrier?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigJim85, Jul 1, 2002.
  1. BigJim85
    BigJim85 1/2 ton status
    Sep 7, 2000
    113
    Lakewood, Colorado
    3.08\'s to 4.11\'s. Must I change the carrier?
    My Jimmy's got 3.08's in it right now and I'm about to replace my tired 305 with a bright shiny new 350 and would like to upgrade those crappy 3.08's to 4.11's and was just wondering if I need to buy a new carrier as well. I could also use the name of a good place to get new gears. Thanks guys.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Re: 3.08\'s to 4.11\'s. Must I change the carrier?
    That depends on what diff you are running.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    in 12 bolt axles thje 2.76-3.42 use 3 series carrier and 3.73- 4.56 use 4 series carrier,
    can get good used 4 series carriers off board memeber for dirt cheap,
    such as from myself.... i have two 4 series carriers that i need to find new homes for,,
    good luck
    R
  4. BigJim85
    Sep 7, 2000
    113
    Lakewood, Colorado
    I got GM 10 bolts. 8.5 inch.
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    On the 10 bolt axles there is one carrier for 2:56 only and then another one for 2:76 and lower gears.
  6. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Yep, if you have 10-bolts front and rear you do not have to change the carrier's.
  7. BigJim85
    Sep 7, 2000
    113
    Lakewood, Colorado
    Excellent! Now if I could only afford to have them installed... Too complex for my impatient brain.
