3/4 Disc Diesel Master Cylinder?
Discussion in '1982-Present GM Diesel' started by OFFRDK5, Apr 24, 2003.
  1. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    OK. Looking to upgrade my rear axle from drums to discs.
    I have heard some stuff about neeing a bigger master cylinder because fo the dics and being 3/4 ton and all.
    Anyone done this upgrade and did you need to get a new bigger master cylinder. Do you have any part numbers of the ones you bought? Anything that I should know before doing this upgrade?
    OFFRDK5
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    tRusty has 3/4-ton discs on his K5. He used a 1-ton master cylinder and hydroboost. Don't think he used an adjustable PV either. Maybe PM him... or he may chime in /forums/images/graemlins/wink.gif
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    There isn't much more to add...C30 master and hydro boost system and rear discs (originally 3/4 ton 10 bolt stuff)
    Stops nicely without premature lock-up in the rear /forums/images/graemlins/thumb.gif
    Rene
  4. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Doesn't the Diesel already have hydroboot on it? I noticed you used a master from a 4x2? Is there a difference there?
  5. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I don't know if there were differences in the hydro-boost systems, but my donor was an 83 C30 pick-up. I tried to use my half ton master with the hydro boost but it wouldn't fit so I used the C30's master as well. As far as I can tell the front calipers on the C30 look to be almost identical to the D60 calipers...so I don't think there would be any difference between the C30 master and the K30 master.
    Rene
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    He put the diesel in his truck it was a gas engined truck so he didn't have the hydraboost. /forums/images/graemlins/thumb.gif
  7. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Duh!! /forums/images/graemlins/rotfl.gif I shouda known that!! Too many hours of work!!! /forums/images/graemlins/rolleyes.gif
