3/4 disc swap rotors
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Predator, Aug 14, 2001.
  1. Predator
    Predator 1/2 ton status
    Jun 19, 2001
    130
    OKC,OK
    When swapping in the disc brakes on a 14FF using the new TSM brackets, do you need the 3/4 ton rotors and calipers off a 2WD or 4WD or are they the same? Thanks.
  2. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I do not know if they are the same or not, but you are looking for calipers for a 3/4 ton 4x4... (man this conversion goes really smooth actually)
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    My TSM brackets required front rotors from a 1980 F-250, 4WD. The recess on the backside for the heads of the studs is too small for the 14-bolt FF studs. TSM will sell you rotors with the recesses machined out larger, for big bucks of course... I just ground a few thousandths off of the heads of the studs (they're huge mutha's, so a little missing metal shouldn't make much difference) so they fit into the recess on the Ford rotors. Got the rotors for $34 each at Autozone. [​IMG]
    My calipers came off the rear of a '76 Eldorado so they have the integral mechanical parking brake.
  4. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    that is the orig. tsm kit... they've changed it since then...
  5. Predator
    Jun 19, 2001
    130
    OKC,OK
    The parts store has two sizes: 11-5/32 x 2-3/4(JB6) and
    13 x 2-1/2(JB7). Which one do I need for this kit? Thanks.
  6. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    You have the older TSM kit, the new kit uses the 3/4 ton rotors with no modifications needed.
  7. Predator
    Jun 19, 2001
    130
    OKC,OK
    I'm talking about the 3/4 ton Chevy 4x4 fronts to be used with the new kit. They have 2 sizes.
  8. Predator
    Jun 19, 2001
    130
    OKC,OK
    Would someone who has done the Chevy rotor swap be so kind as to measure the diameter of the rotors, please. Thanks.
  9. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    when I did the swap I used 3/4 ton rotor's off a 76 D44... hope that helps, if not let me know... my k5's gone right now, but it will be back in the morning.
  10. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Those sizes are for the rear drums.
    Use NAPA #TS4885677 (True Stop) for 78-87 3/4-ton trucks.
