3/4 or 1 ton 56's??
Discussion in 'The Garage' started by steve_kibbe, Sep 17, 2005.
  1. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I have the stock 56 inch springs and a set from a 87 1 ton.
    These are going back in my 3/4 pick up. I use this for hauling dirt, trash, whatever........ and like to hit the trails with it too. Prolly 60% on road, 40% off.
    I will be doing a shackle flip in the future, but not right away. Will run 35-36's at that time.
    Thanks,
    Steve
  2. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I believe the 1 ton pack has 8 leaves, the 3/4 has 7. I'll check and post later.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    There are also light duty 56's out of some Suburbans. They are 5 I beleive. They flex well but they are only 1/2 ton rated I believe.
    Harley
  4. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    I've got a quick question
    So if you're going to put a lifted spring pack on are there adavantages for say going up a rating. For example putting a 3/4 ton or 1ton 6in lift pack on a blazer. I know they are stock half tons but what if you have 1ton axels? Or does the rating have nothing to do with the axles and just weight.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Just weight, nothin to do with the axles. you can use any 73- 87 chevy spring on any truck (if its the correct length)
  6. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    that's all i needed to know thanks
  7. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Just now getting a chance to post up.....
    The 3/4 ton pack has 8 leaves and the 1 ton pack has 9.
    I think I'm going to use the 1 ton pack and use the 3/4's for a future project.
