3/4 or 1-Ton Axles near Midland, MI WANTED
Discussion in 'Parts & Trucks Wanted' started by derek2002, Jan 2, 2002.
  1. derek2002
    derek2002 1/2 ton status
    Aug 1, 2000
    247
    Midland, Michigan USA
    I am looking for a set of 3/4 or 1-ton axles in the Michigan area. Let me know if any are available.
    -Derek
    1986 3/4 Ton 4x4 - 9" Lift, 35's, TPI 350!
    <a target="_blank" href=http://www.4chevy.com>http://www.4chevy.com</a>
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Try Dad's 4x4 in Lennon. I bought a used 14Bff for $275 there a few years back, as well as all the parts neccessary for a Front Dana 44 1/2 6lug to 3/4 eight lug conversion. Watch out, the guy try to push off a couple of axles that had been sitting underwater in thier yard for several years, when I made him let me crack the covers I found some major damage...... They're pretty knowledgable though....just watch what your buying...
    Dad's PickUp &amp; 4x4.
    793 North Durand
    Lennon, MI
    810.621.3100
    BlazerMan
  3. wrath
    wrath 1/2 ton status
    Mar 4, 2001
    182
    Grayling,Michigan
    Hey derek..I'm up in Grayling(originally from Bridgeport).I have a 14ff rear complete with 3.73 ratio..also have a dana 44 front 3/4 that would need rebuilding (all tore apart) ..I believe everything is here for it except gears (originally 4.10s) but the gears got wiped out..reason its tore apart because it would need bearings and ball joints and etc etc..would let it go cheap if interested ..it does have the raised steering arm on it for lift..also have a complete set of front and rear 4.10 gears here.( I believe the 14ff 3.73 is the same carrier to accept the 4.10s).if interested get in touch and we'll talk..
    70K5 350ci.350/205 "PROJECT 40"BOGGERS" It runs and its clean !!
    <a target="_blank" href=http://communities.msn.com/OurMudToys/the70k5blazer.msnw>http://communities.msn.com/OurMudToys/the70k5blazer.msnw</a>
