3/4 or 1 ton NP 203?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by doc70sub, May 25, 2002.
  1. doc70sub
    doc70sub 1/2 ton status
    Oct 8, 2000
    688
    Thomasville, NC
    Hey Guys/Gals,
    I just purchased a 14-bolt FF for my '75 K-10 or '79 K-5 (might be selling the K-10) & have a question. Are there 3/4 or 1-ton output yokes for the 203 transfer case? I'd like to run the full heavy driveshaft when I install the 14-bolt. I know you can get the hybrid or bastard u-joint, just seeing if there are any options first. Thanks!
    Doc
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    I believe there are different choices available for yoke sizes on the 203.
    I removed a 400/203 from a '79 K20 and the yoke size at the 203 end was the 1310 joint.
    The joint end at the 14FF was the standard 1350 series yoke.
    I have no idea why GM must have mixed and matched the yoke sizes on the rear 203 outputs. /forums/images/icons/tongue.gif
  3. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    i pulled the 203 i have out of a 74 3/4 ton and it had the 1350 yoke already in place.i also took the driveshaft out and had it cut down to fit my K5.haven't had a lick of trouble with it yet.
  4. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    You can purchace the 1350 yolks from driveline shops for the np203.. Jesse at High Angle has them, Arizona driveline does too.
  5. doc70sub
    Oct 8, 2000
    688
    Thomasville, NC
    Thanks guys!
    Doc
