3/4 or 1 ton???????????
Discussion in 'The Garage' started by BamBamblazer, Jun 5, 2003.
  1. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    Just a quick question. Will a 1 ton 14ff bolt directly in a /forums/images/graemlins/k5.gif or is it just the 3/4 ton ones that just bolt in? If the 1 ton doesnt bolt in how much difference is the in the spring pad spacing?
  2. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    3/4 works, one ton is 2" narrower between the spring pads I think.
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Yeah 1tons are 2" narrower 40.5" instead of 42.5"
    Couple good things about having to move the spring perches you can make a custom spring perch that incorporates a ZeroRate and/or an offset and you can set your pinion angle also.
