3/4 rear springs on FS Jimmy
Discussion in 'The Garage' started by jeff l, Jun 18, 2006.
  1. jeff l
    jeff l 1/2 ton status
    Jun 13, 2006
    104
    New Orleans
    I am rebuilding a 14bolt SF 9.5 8 lug rear axle, To go on a 1986 Jimmy.
    Does any know if 3/4 springs will bolt right in?
    And would they give me more lift?
    Where should I get bushings?
    Thanks for any input,
    Jeff
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    3/4 ton springs? they won't give you any lift unless your stock 1/2s are worn out. They will not bolt right in. they are 56" long and the stock 1/2 tons are 52" long. Need to move the stock rear hanger back farther.
  3. jeff l
    Jun 13, 2006
    104
    New Orleans
    Would u just use the 1/2 ton springs?
    B/c I will be towing a 3K pound stump grinder for the next year;after that I am going back to school, I then would use the truck as a daily driver, not as a work truck and, plan to buy lift springs and bigger tires.
    Thanks, Jeff
  4. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    i have a set of 3/4 tons that are 52's
  5. Disciples Performance
    Disciples Performance 1/2 ton status
    Dec 6, 2005
    404
    Kelowna BC, Canada
    hey guys i am also gonna be swaping both axles 14FF into my k5 plus a 44 up front now is it that none of the 73-87 chevy 3/4 tons came with 52" springs? cause mine are out of a 79 3/4 ton also and how far back does the hanger have to go back in order to make it fit???
