3/4 swap update **pics**
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Aug 22, 2001.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    <a target="_blank" href=http://www.nashvillek5.freeservers.com/newpics.htm>www.nashvillek5.freeservers.com/newpics.htm</a>
    Here now try this.<P ID="edit"><FONT class="small">Edited by ftn96 on 08/24/01 07:46 AM.</FONT></P>
  2. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Re: 3/4 swap 1/2 done
    I got my U-bolt's from ORD..
    Took less than 1 day for them to arrive.. [​IMG]
    Now I'm waiting on my LMC part's.. and the rest of my wheel's before I begin..
    But the axles and two wheel's are all painted up.. Nice Semi Gloss black.. No grinding need's to be done on my front rotor's.. wooo hoooo..
    I'm in no hurry now.. Just want all my parts to arrive.
    I haven't failed, I've found 10,000 ways that don't work. www.rocko.rockcrawler.com
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    How no grinding? You getting 3" backspaced wheels?
    What is and what should never be....
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  4. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    I bought rim's with 4.5 inch backspacing.
    Tech 1's... Great quality rim's.. I scuffed them up already.. and painted them Black.. They look purty on those axles..
  5. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I just painted my wheels and axles too! I'm still waiting on my Ubolts. I just need to mount my tires and I should be ready to start swaping this weekend. I guess August is axle swap season!
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers... and it's still not BIG ENOUGH!!
    <a target="_blank" href=http://coloradok5.com/gallery/K5Jungle>http://coloradok5.com/gallery/K5Jungle</a>
  6. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Ahhhhh, if you got 4.5 inch backspacing your gonna be grinding a butt load of material off the calipers and backing plates. As far as the Tech1's. Thats what on my jimmy in those pics on my website. The have been good hweels to me. I like the Bart wheels alot better. If you'll notice on the backside of those Tech1's you'll see 4 welded beads about 4 inches long that hold the wheel together. My barts got one long a$$ bead all the way around. It may not make it that much stronger but it sure does something for the piece of mind factor.
    ROCKO, happy grinding fella!!![​IMG]
  7. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Brandon..
    What are you going to do with your rear brake lines with the 14 bolt? Will the old 10 bolt brake line's mount up to the 14 bolt backing plates?
    Just thought of that ...
  8. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Rocko,
    Yes, your 10bolt brake lines will hook up fine.
    Boss
    Pic of my truck in the Early Days
    <a target="_blank" href=http://coloradok5.com/gallery/Stock-Master>http://coloradok5.com/gallery/Stock-Master</a>
  9. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    If your talking "aboot" the hard lines, yes they old ones will bolt right up. and the ones that were on my 14 got hacked off at the 3/8 flare fitting where is screws into the backside of the cylinder cause I couldnt' get the SOB's to turn at all. Even with PB Blaster, vise grips, flare wrench. It was not going to turn so I hacked it off and got new cylinders.
  10. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Cool.. that's where mine are hacked off on the 14 bolt..
    Good to know my line's will bolt up.. appreciate the tips..
    Anticipation is killing me awaiting for all my parts..
  11. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thanks Boss and Brandon..
  12. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    I'm hoping my U-bolts will be there this afternoon. Im also gonna have to have some shims made to re-angle the rear till I can get the perches rotated for the angle I need to run the CV shaft. Looking like Im gonna need a 10 degree shim. MAN that sounds like alot dont it? [​IMG]
  13. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Got my rear axle in today... And had two of my rim's and tire's mounted til the others come in..
    Man.. that rear look's beefy under the Blazer..
    Now I'm just waiting for my other 3 rim's to come in... [​IMG]
  14. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Man, I hate that "waiting period". It seems like an eternity when you have to wait for bada$$ new parts...
    Constipated people don't give a crap!
  15. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    I hear ya big tex..
    Now after putting everything back together.. I need bigger u-joint straps.. Damn.. it's alway's something..
    Got the axle all bolted up, New rear extended brake line put on, Hooked up the ebrake cables, Tightened all the brake lines.. And last but not least.. put my new rim's with my 35's mounted on the rear.. now the rear sit's 2 inches higher than before.. [​IMG].
    Look's like it's time for the extended front shackles and zero rate springs' for the front..
  16. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    WEll, ROCKO I got my 10 bolt out and the 14 ready to jack up adn no u-bolts yet!!! So I clean up for the night and the freaking UPS man comes to the door with what?????[​IMG]
    My freakin u-bolts. Plus the Titans are playing right now.
    So I'll have to wait till tomorrow and put the rear in.
  17. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    ttt for pics
  18. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Looking good!! I'm jealous. I'm stuck here at work and can't finish my swap till I get home [​IMG] Did you start on the front yet?
    Rod
    Alameda, CA
  19. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Yep, the front is done. The rear is ready to bolt in minus the E-brake issue. Im working late this afternoon. So it'll be later tonight for I can start.
  20. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    Nice pics Brandon. [​IMG]
    <font color=green>Joe Angelicchio
    <a target="_blank" href=http://community.webshots.com/user/jangelicchio>http://community.webshots.com/user/jangelicchio</a>
    Lisle, Ontario, CANADA</font color=green>
