3/4 ton 14bff and D44 axle tube diameter.
Discussion in 'The Garage' started by colbystephens, Nov 11, 2005.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    hey, can someone run out to their pre88 (i think that's the year split) and find out what the diameter of the axle tubes are for these axles (i have '78 running gear, just in case i'm wrong on the year splits. I need to go pick up some ubolts and ubolt/spring mounting plates, but my truck is an hour away from me so i can't go check before i go to get the bolts/plates. thanks!
    colby
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    IIRC, it's 3 3/8" dia.
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I dont have a caliper to measure with, but the 14bff has a bigger tube than the 44.
  4. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    is that for both the 14b and d44 diameters? i didn't think they were same.
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    the 14ff is 3-3/8" tube diameter, and IIRC the 44 is 3", but don't quote me on the 44
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    Muddytazz - do you know of any good places around here that can do the u-bolts and mounting plates for me? i'm having trouble finding anything - places can do the u bolts but not the plates, or plates and not the bolts, but either way whatever places can do either are not in the same city and its drivng me nuts. i want to get my 3/4 ton gear under my truck today after installing my lift - and on behalf of my poor planning i'm struggling to get this ever so minor detail in order. :)
    colby
  7. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Try calling a junkyard for the plates. That's what I did, $30. Or they are $19 a piece from GM parts.
  8. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I have a set of u-bolts infront of me right now, the smaller size for the 10b/d44(I believe are the same size) is 2 7/8" and the biger one is 3 9/16".
    The center to center on the small one is 3 3/8" and the big one is 4 1/8"
    The 14BFF ubolt is 3 9/16" and the center to center is 4 1/4"
    Hope this helps more then confuses :crazy:
  9. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i tried the junk yards i have avail. to me around here and they wanted something like $50 for just the rearend - i'm not too keen on that. :)
  10. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    it won't help you today, but I got my u bolts from here
    IIRC they were $27 shipped to my door for my 14bff and 10b/d44.
  11. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    14bff- 3 3/8" tube
    d44 75 and older- 2.75"
    d44 76 and newer and 10 bolt- 3" with a 3.5" at the pig.
