3/4 ton 1970 truck...what came under it?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Apr 12, 2001.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    What axles and transfer case and tranny came with the 3/4 ton 1970 pickup trucks?
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Corporate rear drop out rear with 10.25" ring gear, OR a Dana 60 (the corp has a round cover), Dana 44 front, open knuckle drum brake, TH350 auto trans, or 465 manual, and a NP205 case.
    ken
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Also, that front has the smaller 260-X steering u-joints as compared to the 297-X u-joints that come in 73+ fronts.</font color=blue>
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    So it's got front shoes and not pads...when did they start using pads?
    89 K5 Silverado
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Front disks were standard in 71. I would look for a 73+ front so you get the disks and larger steering joints (I broke both of my 260-X joints at the same time with 33s). If It's an Eaton drop out (kinda looks like a big full-floating Ford 9") I would pass, they're getting hard to find parts for. Either way, the rears wont bolt up. You will have to have the spring pads and shock mounts moved.</font color=blue>
  6. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Some of the '73 front axles had the smaller U-joints...like mine. I was pissed when I figured it out. I hear its a low number though.
    '73 K5
    Chevy good...Ford bad
  7. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Alright...I was wondering because someone here local has a complete truck minus the engine for $450. But sounds like it wouldn't amount for much.
    89 K5 Silverado
