3/4 ton 44 With 15's?
Discussion in 'The Garage' started by muddawg, Mar 10, 2005.
  1. muddawg
    muddawg Registered Member
    Oct 24, 2004
    39
    Susanville, CA.
    Exactly how much grinding and where is needed to fit a bart 15x12 wheel with 4" of backspace on a 3/4 ton dana 44? Will it compromise strength in any way?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    With 12" wide wheels you are probably going to be spending alot of quality time with your grinder. Most people say you need to grind your calipers which is true but the most grinding for me was on the caliper brackets, not the calipers.
    Harley
  3. muddawg
    Oct 24, 2004
    39
    Susanville, CA.
    also i am running a 14 bolt rear with the disc conversion, i don't think i'll have any issues with that?
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    You will have to grind the same as everybody else with 4" of BS (same harley has 4.25"). How wide of a tire are you running for those wheels?
  5. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    When grinding I would use a flap disc they cut faster and cleaner IMO. I had 15s with 3 3/4 backspacing and I just would grind until I could spin the wheel freely
  6. muddawg
    Oct 24, 2004
    39
    Susanville, CA.
    i'll be running a 37x14.5 toyo tire
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    D60 and 4.25 backspacing here, plenty of grinding, but well worth it.
    If you don't have the tires yet, get 16s or 17s. Preferably 17s. It's the wave of the future.
    Flap discs are slower and remove less material than a regular disc, but will make a cleaner cut. No use in this application, unless it's to finish off the job.
