3/4 ton and 1ton crewcab frame difference?
Discussion in 'The Garage' started by stoney126, Jul 14, 2006.
  1. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    Hey all, What are the differences between the two? Size of the frame or shape?
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I believe 1 tons had bigger frames
  3. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    There is a guy on pirate with a 3/4 ton crew with a 6 foot box. The way he did was cut off the spring hangers and move em forward. I was wondering If the dimensions or shape of the frame on the 1 tons would let me do the same:confused:
  4. 1BadK-30
    1BadK-30 1/2 ton status
    Feb 6, 2005
    817
    Phoenix, Arizona
    i believe there all the same but the 1ton has a 9 inch tall frame and the 10 and 20 have 6 inch tall frames.
    someone correct me if im wrong.
  5. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    SO a 1 ton frame would be kinda like a body lift?
  6. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    When it comes to the crewcabs the 3/4 and 1 ton are the same frame. On the reg cabs there is a different frame.
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    My crewcab began life as a 3/4 ton. It has a one ton frame so they are the same.
  8. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    So did mine. I was trying to say that all 3/4 crewcabs are really one tons but in the regular cab versions that is not the case. Crewcabs are 1 tons reguardless of what badge is on the fender.
  9. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    That's what I was thinking.
  10. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    So far as the frames go, yes.
    The 3/4-ton crews got the lesser JB7 brake system common to 'normal' 3/4-tons.
  11. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    Hmm so I dont need to cut the frame to fit the 6 foot box, looks like me and the tape measure are going to spending alot of time together :D
  12. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    As everybody else said, the frames on the crewcabs for 73-91 are identical for 20 or 30 series, likely due to the small number produced. They are the thicker/taller frame with the narrow spring spacing in the back.
    The regular cab trucks were manufactured in enough quantity to make variations cost effective.
    Note that my C20, a '74, came with the same stuff a light-GVWR 1-ton regular cab would have ... same spindles and brakes up front, same springs in the back, etc, but the extra weight of the body meant they had to back off on the GVWR.
    I upgraded it to SRW C30 just by changing the springs in the back to the nine leaf plus overload monstrosities.
    I then went nuts and did DRW, hydroboost, etc etc ... but that's another story.
    -- A
  13. dremu
    Feb 27, 2000
    15,954
    445
    Ah, is that what you're thinking about.
    Note that some crewcabs started out life as cab-n-chassis', and they have a different frame in back ... prolly easier to put a shortbed on those, as IIRC the frame is flatter / straighter.
    -- A
  14. u2slow
    May 9, 2001
    2,217
    BC Canada
    Same frame actually... just the narrower axle. ;)
  15. dremu
    Feb 27, 2000
    15,954
    445
    I thought there was the option for straight axle rails ... maybe that was the 88-91 NBS C/K C&C's. Aargh, my memory =))
    -- A
  16. u2slow
    May 9, 2001
    2,217
    BC Canada
    Tsk tsk :shame:
    I thought for sure you'd have committed those brochures to memory by now. :rotfl:
