3/4 ton axels
Discussion in 'The Garage' started by coptezr, Apr 10, 2005.
  1. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    will a 3/4 ton rear end from a burb fit a k5? and the burb is not 4wd so will it work if i got a 3/4 front and what do i need for a transfer case ?
  2. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    yeah the rear will fit
  3. coptezr
    Jan 13, 2005
    342
    now do i need the drive line to the 3/4 and what about a transfer case?
  4. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    your current t-case will be fine...
  5. mrhoes
    mrhoes 1/2 ton status
    Jul 20, 2002
    123
    Austin, Texas
    the 3/4 ton 14 bolt should work, you can either get a 8 lug dana 44 or 10 bolt front or convert your 6 lug front to 8 lug
  6. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    Your t-case will work fine, you'll just need a conversion u-joint for the rear d-shaft to the 14b pinion. NAPA sells one for about $23 (I bought mine from them but don't remember the part # right now.) Do a search for the new part number
    Edit: From one of my earlier posts..."NAPA has a new part number for the #447 u-joint (I bought mine a few months ago). New part number is #240-0447. Cost is $23.99"
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    4x2 and 4x4 1/2 and 3/4 ton are all 42.5" spring pad centers,
    (73-up K-5's)
    all same deal
    happy swapping
  8. Blazer guy
    Blazer guy Registered Member
    Jan 13, 2005
    8
    Blythewood,S.C
    In the middle of the same swap myself.Rear out of 85 2wd sub,front out of 85 sub.My 81 had 12b need napa ujoint #2400358.Shock mounts on 2wd rear seem to be set lower but dont know if that will hinder shocks when axle is pivoted.Will also need ubolts for 14b.
  9. coptezr
    Jan 13, 2005
    342
    thanks guys any pics?
