3/4 Ton axle questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bayou blazer, Sep 15, 2004.
  1. bayou blazer
    bayou blazer 1/2 ton status
    Jul 16, 2004
    176
    la
    I recently picked up a set of 3/4 ton axles for the Jimmy. They were a D44 and a 14 bolt full floater. I was wondering what parts are interchangeable between the 3/4 ton and 1 ton version of the 14 bolt FF. Also what parts will interchange between my 1/2 ton 44 and this 3/4 ton front. O.K. one final question, are the axle tubes on the 14 bolt FF and the 14 bolt semi floater the same? I have access to a rear axle for free and wondering if it worth my time to grab the u bolts and spring pads for my axle. Thanks.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Everything will interchange
    Everything will interchange here also(except if one is a 10bolt and one is a D44, from the knuckles IN will not interchange). Only other thing I can think of for this part is if you have 1 1st design D44(small bearing)and 1 2nd design D44(bigger bearing)no mix and matching stuff here, use one or the other.
    I don't know the axle tube diameter of a 14SF, but me personally, I would never reuse used u-bolts, to unsafe, just my $.02
  3. bayou blazer
    Jul 16, 2004
    176
    la
    Thank you for the info. I do indeed have the larger bearing D44 for both of them. I guess I will go ahead and get new u bolts for the rear. Thanks again
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    The FF is much larger than the SF. Nothing is enterchangable between the two.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    Are the axle tubes a different diameter? I thought I heard about the spring pads being useable for either 14B.
  6. one ton burb
    one ton burb 1/2 ton status
    Nov 15, 2003
    119
    Ontario, Canada
    [/ QUOTE ]I'm preaty sure the axle tubes on the 14bolt ff and the 14 bolt sf are the same size. /forums/images/graemlins/thumb.gif
