3/4 ton axle questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fr8train, Sep 30, 2000.
  1. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    How much would the HD44 typically cost, also what would be the typical gear ratio? Anyone know what the standard gear ratio was for the 14 bolts? Or does anyone have axle codes for the 14bolts and D 60's. Are the 14 bolts or D 60's found on 3/4-1 ton two-wheel drive vans? Are there any diffrences in these compared to the ones found on 4x4's. Is the spring pad location the only reason why the 1 ton axles wont match up to a K5? And finally what is the difference in dually axles and non-dually?
