3/4 ton axle swap and 4 in lift ?'s (no it isnt what size tire will fit)
Discussion in 'The Garage' started by 85army tank, Aug 18, 2004.
  1. 85army tank
    85army tank 1/2 ton status
    Sep 25, 2002
    276
    southren mn
    3/4 ton axle swap and 4 in lift ?\'s (no it isnt what size tire will fit)
    /forums/images/graemlins/k5.gifThis shouldnt be a real hard question.But i have an 85 blazer that i am doing a 4 in lift and 3/4 ton axles swap.The axles are from an 80 3/4 ton truck.Any way the ends of brake lines from my truck are diffrent then the caliper.It is just the shape of the end of the line that is diffrent then on the caliper.The question i have is has any one ran in to this.I was thinking of getting sst brake lines and was wondering if any one had a part number or any thing that would fit.What lenght would i need for my 4 in lift? /forums/images/graemlins/k5.gif
  2. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Re: 3/4 ton axle swap and 4 in lift ?\'s (no it isnt what size tire will fit)
    Your calipers will be the same. I just ordered 6" extended lines for my blazer's stock calipers, used the calipers I already had and added new pads. 3/4 and 1/2 ton calipers are the same btw /forums/images/graemlins/wink.gif I used explorer pro comp brake hoses. They're nice and come with a complete set. I'm going to be upgrading soon to go with 12" hoses because I added a lot more lift and travel to my suspension. My hoses have very few miles on them since my blazer has been sitting in my driveway for about a year now, /forums/images/graemlins/doah.gif
  3. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    I had the same problem on my swap....I just swapped calipers from the old axle to the new one! /forums/images/graemlins/peace.gif
  4. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    the 3/4ton axles probably have a 7/16ths banjo bolt and your blazer uses a 10mm. had the same problem when i swapped axles. /forums/images/graemlins/thumb.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nope, all 10 bolts have 10mm, as does the Dana 60.
    There IS a difference between SOME 3/4 ton calipers and 1/2 ton ones, but either will bolt in the place of the other. There are two different sized pistons based on brake system code.
  6. 85army tank
    Sep 25, 2002
    276
    southren mn
    /forums/images/graemlins/k5.gifthanks for the info.maybe tonight i will swap calipers. /forums/images/graemlins/k5.gif
  7. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    They are the same except for the banjo bolt. D44 and 10 bolt used different banjo bolts.
  8. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    When I swapped my 3/4 ton axles in (D44 in front) I used extended SS lines for a 1/2 ton axle with no problems.
