3/4 ton Axle Swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RobbieOH, Feb 15, 2002.
  1. RobbieOH
    RobbieOH Registered Member
    Feb 15, 2002
    79
    Shoreline Washington 98133
    I Have a 75 K5 with a bad rearend, and my friend said he had a set of 3/4 ton axles that I could put in there. My question is: are the yokes the same and will they bolt directly in place of my 1/2 ton axles? Also, I what other modifications will be necessary to put these axles in my Blazer?
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    The front yoke is the same but the rear is different. You can get a conversion u-joint from NAPA(#447) for about $30. It will fit your stock driveshaft to the new rear yoke. They are a direct bolt in, but you will need thingfs such as:
    u-bolts
    8 lug wheels
    the rear u-joint
    I think thats all, atleast all I can think of off hand.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  3. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    There are actually two different ujoints for this conversion. Most seem to use the one mentioned above but there is another, of course, I can't think of it right now. If you have a 75 then as long as the 3/4 tons are from an 84 or 87 (I have heard both) and older truck they should slide under there fairly easily but with the hassles outlined above. NOTE- The e-brake can become an issue but I think the brakelines should hook up fine.
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s/6superliftand33s.msnw>http://communities.msn.com/OffroadK5s/6superliftand33s.msnw</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  4. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    The joint is a #348 for that year. The E-brake will bolt right up.
    A set of 8 lug 15x10 's cost me 191 delivered.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  5. 87superblaze
    87superblaze 1/2 ton status
    Mar 12, 2001
    104
    Upper Michigan
    There are a few issues when converting. I had a few problems because my 3/4 ton axles were from an older truck.
    --Keep the front brake lines from the 3/4 ton axles. They will cost $90 to replace and you 1/2 ton line won't work.
    --The axle tube may be smaller on the 3/4 ton (D44) so new U-bolts will be an issue along with the pads. Also if you have a dual steering stabilizer set up, those U-bolts will be different.
    --8 lug wheels instead of 6 lug and the grinding of the brake calipers if you want to stay with 15" wheels and tires.
    --The emergency brake line on the rear
    --Rear U-joint
    Thats about all I can think of right now. I am currently going throught the swap this weekend and last weekend. I am sure the benefit will by far out weight the time to do it.
    Make sure the axles are in good condition!! Then you won't have a hard time like I am having.
    Good Luck!!
    My Truck <a target="_blank" href=http://www.community.webshots.com/user/nicksm79>http://www.community.webshots.com/user/nicksm79</a>
