3/4 ton axle swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dammit32, Sep 8, 2002.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    i am trading out my 1/2 ton 10 bolt carrier(6 lug) for another 10 bolt carrier(8lug) cause the gears match my new 14b ff and i want 8 lug all the way around. i am still going to have 15" rims and i was wondering if they will clear the calipers on the new axle. can i swap the calipers from my 6 lug axle? also i have new ball joints in the old axle ...can i swap the whole hub or do i need to pull the ball joints out and put them in the new one? ...the part #'s for the ball joints are the same
    my new axles are from a 78 3/4 ton truck
    any help is apreciated /forums/images/icons/smile.gif
  2. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    ah done this one before /forums/images/icons/smile.gif
    in my case i used 73 axles and 15's. had to grind the caliper's and i used some spacer's.
    back should be fine.
    it was kinda a pita and then after a couple of month's i ended up buying 16.5 tires and rim's anyway. /forums/images/icons/frown.gif
    dave
  3. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    yes, yes and yes
    you can run 15" wheels but you will need to grind youre calipers. youre calipers will also work on the 3/4 ton axle. and you can swap over youre ball joints im sure, everthing is the same with 1/2 and 3/4 ton only difference is bigger rotors and 2 more lugs.
    8 Lug conversion
    that might help with any other questions you might have
