3/4 ton axle swap.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Moose, Sep 25, 2000.
  1. Moose
    Moose 1/2 ton status
    1,062
    Glendale, Arizona
    Well finished the axle swap. DAM is all I can say, I now have to Master Cylinder Booster and probably the valve too. I will post some pics up later.
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
  3. Moose
    1,062
    Glendale, Arizona
    Took me about 16 hours total. Let me know if I can help. I will email a list of things you might/or might not of thought about. Also what are you doing for tire/wheels. I put 15x10 on. If you need some I can get Crome mods for 56.00 each with the 8 lug pattern.
  4. rich'90
    rich'90 1/2 ton status
    Feb 27, 2000
    159
    Savannah, GA
    Moose, I just ground up some teeth on my 10bolt and now have a junkyard 14bolt(FF) sitting next to my blazer waiting to go in. Not sure what I am in for. Could you possibly give me some hints. Also, did you use wheel spacers, if so what size and where did you get them. I want to use my same tires but can't get 15x10 rims in my type with the 8 lug. Any info you could give my would be great.
    thanks Rich
  5. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    When I installed my 14 Bolt FF, I didnt have to upgrade the MC or Proportioning valve. Brakes work just fine and have done so now for 3 years
  6. tRustyK5
    Jul 23, 2000
    36,188
    1,393
    E-town baby!
    I did the same, 3 years now on the 3/4 ton stuff. 1/2 ton front calipers, stock MC and propotioning valve and the brakes work awsome.
    Rene
  7. Moose
    1,062
    Glendale, Arizona
    Parts I didn't think of were new perches for my 14 bolt. New plates & ubolts front and rear. My Dana44 tube is 1/2" bigger than my dana44 1/2 ton. New cylinders in my 14bolt. New brake lines. And 15x10 chrome mods to fit my new 35" bogger. Any one know about why my 14 bolt is 6" wider than my 12 bolt. Both axles came from a M1008 LB.
  8. Boss
    2,550
    Maryland
    Thanks for the list Moose. I emailed you about the wheels and the list a couple of days ago. Don't know if you got it or not. Do you have 16" wheels? Thanks
    Boss
    http://www.boss.coloradok5.com
  9. Moose
    1,062
    Glendale, Arizona
    No. I'm running 15x10 wheels. Had to do some grinding on the front but nothing major.
  10. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    Hey my 12 bolt just bit the dust and i got a 14 bolt FF siting around. i'm really low on cash. and need my truck up and running again. what all do i need to put in the 14 bolt? from what i can figure is i need new u-bolts and my driveshaft altered to fit. my gears will be diferent. but that dosn't really matter so long as i don't put it into 4wheel drive right? will 15 inch rims fit on a 14bolt FF? there are 16.5 on there now (ugly as hell too). i would still be running a 1/2ton dana 44 up front with 6 lugs.
    (man if i do do this its going to be the funky blazer [​IMG])
    From the Grave to eat the Jeeps
  11. CK5
    May 19, 1999
    21,627
    704
    CO
    I know what ya mean.
    5,000 Pounds of American Rolling Steel
  12. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    that is exactly what it would look like got those same rims.(but not sure if the 2 on the 14 are the same look the same. one might me a 16inch and the other a 16.5 inch)
  13. CK5
    May 19, 1999
    21,627
    704
    CO
    Have you read my axle swap article yet? if not, click on the "technical" link at the top of this page and check out the "axle swap" article.
  14. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    Oops toatly forgot about that. [​IMG]
  15. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    i heard the 14 blt. ff will fit 15s fine.....can i use 1/2 toon rotors on the front d44(which is 3/4) and still use 15s on the front ???? what about brake hoses, do they interchange?
  16. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I think The calipers are the same. I have some junk 1/2 ton calipers and I fitted them to my 3/4 ton 44 and they matched up. Only a bit of grinding is necasary.</font color=blue>
    http://www.chrisd71k5.coloradok5.com <font color=blue></font color=blue>
  17. Moose
    1,062
    Glendale, Arizona
    Yes I used my Dana44 1/2 calipers and bolted right too the 3/4ton setup.
  18. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    where can u get 15 inch wheels with the 8lug pattern? i got 16.5 on a 14 bolt FF. i don't want 16.5 no bead locks and 16inch rims are hard to find tiers for. at least thats what i have been noticing latly.
    <font color=red> My rear end blowed up </font color=red>
  19. clintsk5
    clintsk5 1/2 ton status
    Mar 2, 2000
    288
    Kingman, Az.
    Where can you find those inexpensive 8 lug 15's?....Been looking at the Eaton wheel from National Tire and Wheel...They run $93 for chromy's and the throw on beadlocks for $75 more...white or black only $68...same deal for the beadlocks on those too!!!I have 16.5 now with 38's....want to run some new Claws on some beadlocks and see how many axles I can destroy!....later tater...~CLINT~....
  20. Moose
    1,062
    Glendale, Arizona
