3/4 ton brakes on 1/2 ton axles?
Discussion in 'The Garage' started by zcarczar, Jun 20, 2002.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I want to keep my six lug wheels, but is it possible to put 3/4 calipers on a 1/2 ton axle, or do i need the whole axle assembly?
    Thanls
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    As far as 1/2 and 3/4 ton disk brakes go, the calipers are the same. The 3/4 ton rotors are 8 lug though. As far as the rear, you cannot put 3/4 ton brakes on a 1/2 ton rear end. You can do a disk brake conversion though in the rear and keep your 6 lug.
  3. zcarczar
    Feb 10, 2002
    2,495
    they are the same? i thought that the 3/4 ton had bigger brakes, isnt that the reason they have 16" wheels instead of 15".
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The front calipers are the exact same for 1/2 ton or 3/4 ton. The 3/4 ton front rotors are about 1/2" larger in diameter but since the caliper is the same you don't gain any better braking from it, just 8 lug. How many 8 lug 15" wheels have you seen lately? There are not many out there and I don't think there are any that are aluminum.
  5. zcarczar
    Feb 10, 2002
    2,495
    oh ok, i get it now, does anybody make a bigger caliper for the front brakes?
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    The only "bigger brake" other than a 1/2 or 3/4 ton is the D60 on the 1 ton.
    And no, the 1 ton calipers will not fit the 1/2 or 3/4 ton. /forums/images/icons/tongue.gif
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    BTW, what are you doing and why are you trying to get "larger" calipers for a 1/2 or 3/4 ton?
  8. zcarczar
    Feb 10, 2002
    2,495
    I just wanted to see what the options were, because i dont want to drop $1000 on a dana 60 when i dont need it
  9. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,139
    14
    Bangor,Pa
    is there such thing as a double caliper that has a piston on both sides for better breaking.i think ive seen them on cars before.or maybe i was just dreaming it up.haha /forums/images/icons/laugh.gif
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, the Fords use a dual piston caliper, but they also use a different caliper mount bracket.
    I would assume with some fabrication, you could make the Ford calipers and brackets work and fit to a 1/2 or 3/4 ton axle. Just expect to spend some $$$ to get the job done. /forums/images/icons/wink.gif
  11. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    That's good to know because people have told me their 3/4 ton brakes have more breaking power than 1/2 tone brakes.
  12. gmule
    gmule 1/2 ton status
    Apr 2, 2002
    196
    Conifer Colorado
